Thunderbird Profile
I copied an old TB profile from an old Windows XP laptop onto a Windows 10 PC. I readup that you should create a new profile using the Profile Manager and copy the old files into the new profile. I did that and then changed profiles to it. It opened as if it was a brand new Thunderbird installation with nothing there. How can I get back to my original prfile as there is no File menu with the option? I'm currently using a version of Thunderbird on another Windows 10 laptop to get and receiver emails, but I'd like to get the PC sorted.
Kaikki vastaukset (2)
It's OK, I found the Thunderbird -p option All is good, just need to sort out what's wrong with the 'old' profile I copied in.
This question has been locked because the original author has deleted their account. While you can no longer post new replies, the existing content remains available for reference.
